Home > Message Board > Car Audio > Navigation Systems > 2006 Ford Factory Navigation
Author Thread: 2006 Ford Factory Navigation
Username: Fastcarguy
Hello Everyone,
I just purchased and installed a 2006 Ford Explorer Factory Navigation unit into my 2005 Ford F150 Pickup. Does anyone have a diagram of the pin configuration for this unit. The Ford part number is: 6G1t-18k931-AD. It is made by pioneer and is similar in looks and operation as the Pioneer AVIC-D1. Everything works great except the map does not move. I have traced this problem down to the Speed Pulse Signal. I know what wire it is on the Ford Wiring harness but I'm not sure which pin it connects to on the back of my navigation unit. The back of the navigation unit has 3 plugs and is exactly the same as the new in dash 6 CD audiophile radios.
Any help would be greatly appreciated.
Thanks,
Fastcarguy
Relevant Product Info
Username: Dsturner
Did you ever have any luck finding the location of the speed sensor pin on the 2006 Ford Factory Navigation radio. I am having the same problem.
Username: Stangray
Here is your fix. The radio needs to be re-programmed for your vehicle. Contact Dominic at ARC 781-721-0092 Cost is $100 Tell them Stan sent you.
Username: Illuminator
Post Number: 4324
Just curious, how did you obtain the new unit (as old as this thread is)? I would have preferred to just buy the Pioneer model and completely bypass the ford logo unless the designated ford model was cheaper of course.
Username: Stangray
I purchased off ebay. Unit, dvd and antenna was approx. $600.00 They can reprogram the radio to match the pinout for the specific ford vehicle.
So for me, it was cheaper than the Pioneer D1 and is pretty close to the same thing.
Post Number: 4338
Wow, not bad at all, then. Who services it if it dies? Do you send it to Ford who then in turn sends it to Pioneer? Or directly to Pioneer?
Username: Stangray
Ford has repair centers in most large cities. ARC who is doing the re-programming can also repair units..
Post Number: 4360
Interesting :-) Thanks for the info.
Username: Berg
Stratford, CT
Does this unit have a video input for a back up cam?
Username: Stangray
There is no factory input for a cam. They do make an interface box that plugs between the harness and the radio. Do a google search for factory ford radio camera.
Username: Mpullia
I just got a unit out of a mecury for my licolin mark lt . does the controls on the steering wheel work and how did your antena hook up also the map does not move with me so i will need a reprogram. do they do that in the car or do you have to send the unit out to them at arc. any help would be great
mike
Username: Stangray
Yes, my steering wheel controls work.
They make an antenna adapter. I got mine at Circuit City. It takes the one for Chrysler vehicles. Cost is approx $12.00.
The reason the map does not move is because the speed sensor information is on a different pin in your Lincoln than it was in the Mercury. Domonic at ARC can reprogram your radio to work.
He will need your truck year, if it has a DVD player, and if it has the audiophile option (sub)
He can also change the logo on startup from Mercury to Lincoln.
Stan
Username: Mpullia
stan thanks for the info can they program over the phone or ? Mike
Username: Stangray
Post Number: 7
Sorry i missed that part of your question.
No, you would have to mail them the unit, unless you live in the Boston area.
It takes about a week to get it back.
Username: Beartrapper
Rural Hall, NC
United States
Anyone know if a factory navigation system out of a 2005 expedition will fit a 2004 expedition. It was took out at the dealer & replaced with a eclipse. It is new, never been used.Can get it for about 400.00. No wireing or antenna. Can i get the wireing & antenna anywhere?
Username: Cadillacdb
Houston , TX
Post Number: 926
i have a built in navigation too.. its my brain
Username: Richards212
will that same unit work in my 05 explorer? It has the double din radio.
Username: Mr_ford
I have a 2006 mustang and I have installed a 2007 mountaineer nav radio. It was programed for me by ford dealer and everything is working fine however I have a speed error fault code U2473. The only issue I am having as a result of this code is that my position on the display is always 100 feet late. I have tried recalibrating position but it just returns shorthly to the late position. I have contacted dominic at ARC and he is looking into it. Does anyone have any cure or remedys that would help clear this code.
Username: Cc1999
Has anyone ever tried puting the factory nav radio for the 2006 F150 in a 2006 F250. I know there size and shape is identical, and the mounting points are all that is different, so i am told anyway. I mainly concerned about the mounting points and will the steering wheel controls work.
Username: 06vistabluegt
West jordan, Utah
Usa
just purchased and installed a 2007 Ford Factory Navigation unit into my 2007 Ford F150 Pickup but i cant get the steering wheel controls to work everything else works but the volume control and the seek control and they said that it was programmed for steering wheel controls anyone know what might be up ??
Username: Stangray
Post Number: 8
Cindy,
The steering wheel controls is vehicle specific. I would guess that the radio you have came out of a vehicle that did not having steering wheel control.
It can be fixed, but it will require you to send it to Dominic to be re-programmed.
West jordan, Utah
Usa
Thank you
Username: Witomskitom
hello everyone
I just purchased a 2006 ford navigation (from mercury) and installed into my 2007 f 150
-I dont know where I should install gps antena
( inside dash or on roof)
-i dont know where i can reprogramed this unit in chicago area ( change logo , set gps map, time, date)
-also i dont know where i can finded user manual for 2006 ford navigation
THANKS
TOM
West jordan, Utah
Usa
you put it inside the dash somewhere where it will clip on and not rattle
check on ebay for a manual
Username: Lewpoberezny
Call Chicago parts and sound. 630-350-1500 Ask for Ray. I paid 100.00 for reprogramming. I suggest you take vehicle with you. That is where I had mine done.
Username: Schimshack
I bought a ford navagation radio out of a 2004 to put in my 2006 expedition but the plugs do not match is a harness avable for this.
Username: Jayguy
I've got a co-worker who saw my factory nav in my '07 Mustang and he's wondering if it'll work in his '04 Ranger. Looks like a double-din unit will fit, the big question is programming and the connectors, will he need adapters?
Username: Docm
Can a ford dealership reprogram a navigation unit or do I need to send it to someone like Dominic above. Also, the nav. system (2007 navigator) I bought didn't come with a disk. Will any of the new FLM disks work in it or does it have to be specific for my vehicle? Thanks
Username: Jayguy
A Ford dealership SHOULD be able to re-program it. I'd call and ask their service department about it.
The nav disks are not vehicle specific, you can just buy the latest version and install it into your system. I don't know if there's a newer version out yet, the latest I have seen is 4P.
This is an example:
http://cgi.ebay.com/ebaymotors/Ford-Lincoln-Mercury-NAVTEQ-Navigation-DVD-NIP-RE L-4P_W0QQcmdZViewItemQQcategoryZ38653QQihZ016QQitemZ260127508017QQrdZ1QQsspagena meZWDVW
Username: Esim1983
New Iberia, Louisiana
U.S.
Last week I purchased a 2007 Ford Navigation System for my F-150, it is a 2007 also. I connected everything to the back of it except for a pink connection that was on the unit, yet I had nothing to connect to it. Everything is working; steering wheel controls, Sirius sat radio, CD player, and radio. The only thing that is wrong is that my GPS is not working correctly. When I put in a POI my starting point is from Michigan. Could someone give me some advice please? I'm thinking that the pink connection on the back of the unit is for a GPS antenna, when I'm traveling the screen shows me roads that I have never scene before. The dealership that I bought the truck from told me that my truck is Navigation Ready, they say I shouldn't have to do anything. Also I can access the DVD player but can't put one in, what’s up with that? Also my Date/Time settings won't let me change them either. If the problem is an antenna where should I go about getting one? Any help is much appreciated!!! Thanks, Elliot
Username: Stangray
Post Number: 9
Elliot,
That connector is for a gps antenna. I purchased mine from a local Mercury dealer. I think I paid around $30.00. The antenna is very small. I wire tied mine to the cable loom, right under the pad in the middle of the dash.
If you are refering to the DVD player in the unit, that is for navigation only. If you are seeing maps on the screen, it sounds like there is one in there already.
Date and time settings come from the GPS. Install your antenna, and that will correct that problem.
Username: Esim1983
U.S.
The person I bought my navigation system from says that it has Bluetooth capabilities but he or I do not know how to set it up. Does anyone know how to use this function? Thanks again, Elliot
Username: Brettb
Kent City, Michigan
I recently bought a ford navigation system. And found that if I push the mute button twice that a hands free phone interface comes up. If I install the ford mobile-ease kit will this enable me to use this feature. As I currently am not able to do.
Thank you if anyone can help.
Username: Wmckay
Fayetteville, NC
US
Post Number: 7
First of all, the 2005 F150, coes not have MS-Can to communicate with your naviagation radio, so no matter what you do, It will not work on a 2005 F150, you can get them to work real good on the 2006, but not the 2005. If you want to sell the nav Radio, I'll take it off your hands. How to test your nav radio for compatibility -- with your can on and in park, press down on present 3 and 6 at the same time and you will access the software settings, also it will give you the codes and tell you this readi will not work in your truck. Fir more info wmckay@nc.rr.com
Username: Stangray
Post Number: 10
William,
I am not sure who your comment is directed at, but since I have a 2005 F-150 I will respond.
I have a working Ford factory navigation system in my 2005 F-150. I do not know where your information is comming from, but I can assure you my system has been running great for 9 months.
Stan
Username: Johnpw
Hello everyone,
I got my self a 2008 ford mustang with a factory installed navigation system and since I will be moving to Europe in a few months I have been trying to locate a "European Disc" compatible with my unit. Haven't done much yet, Ford tells me that they don't have a "European disc" and NAVTEQ hasn’t send me a response yet...
Username: Jetmech7065
Seattle, Wa
Usa
Help I justt got a 2006 lincon nav system P/N 6H6T-18K931-AP (AVIC-1557ZFS3 /XHUC) for my 07 mustang. When I installed the NAV unit I got power could change radio stations and play cds but I cant turn up or down the volume but the valume indicator moves up and dwn on thee screen when I move the volume control I get sound but its to damm loud also I can't set the time/date and the gps don't show me in my state it shows me in MI on the American Road ?? any help would be great thanks }
Username: Wmckay
Fayetteville, NC
US
Post Number: 9
Yes, I have, call me @ 910-864-0646
Username: Wmckay
Fayetteville, NC
US
Post Number: 10
It's a 2008 Nav Radio, there is a moudule you have tobuy from the ford dealer
Username: Johnpw
Hi William, is you post a reply to my post or to Jonathan's post?
---John---
Username: Jb_brown
Have an 2007 Lincoln MKZ and want to install navigation from a 2006 Zepher. The screen is very scratched. Can screen be replaced, anyone know who could do this and approximate costs?
Username: Jstrazz
just saw this post and have a couple of questions. I picked up a factory nav. unit from an 07 expediton for my 07 f150 as a little present for myself. When I plug it in it will power up and display the ford symbol then shut down. do you guys think this could be a programing issue or is the radio doa . thanks guys Jay
Username: Wmckay
Fayetteville, NC
US
Post Number: 12
Sir, You need a 7L3T-18K93, the radio you have is 7L1T, will not work because of the power on configiration. It much easier to get the right one.
Username: Jstrazz
that bites. thank you for the fast reply. is there any way of rewiring it to get it to work.if not it should work in my wifes 05 expedition. thanks again Jason
Username: Jstrazz
I just looked at the radio it's a 8L1T-18K93. can this be reprogramed to work. thanks guys Jay
Username: Wmckay
Fayetteville, NC
US
Post Number: 13
Sir, the radio has two 12 volt input, one is continous and the other comes on with the acc. In some F150's, there is a relay in the power line to the radio --- when the processor recognize that the radio is not the right one, the relay cuts the radio off. I sent a radio to the ford service center and had it reprogrammed for an F150 and it never worked. The F150 still has old technology. You need to get the one made for you vehicle and move on! If you want to sell yours, I'll take it off your hand.
Username: Jstrazz
I live not to far from ARC they took care of it. they reprogramed the radio and all works great.
Rural Hall, NC
United States
Does anyone know if you have to take the dash out of a 2004 expedition to install a factory navigation sysyem?
Username: Wmckay
Fayetteville, NC
US
Post Number: 14
No, just remove your radio. Then there is a special dash plate for the Nav Radio in a 2004 Expedition to make it fit. You must must get the plate from the Ford dealer or the Salvage Yard.
Rural Hall, NC
United States
Thanks for the info William, but a don't think i can remove the radio because of the woodgrain dash kit that i installed. See no way of getting it out . Don't want to remove the dash. Guess i will stick with the Garmin 650 that i have.
Username: Jamjr3
I also have an f-150 with the audiophile and have the same problem as jstrazz did, it turns on and then turns off right away. The number on my nav unit is 8F9T-18K931-FA. Any recommendations. I live near Chicago.
Contact Ray @ Chicago Parts and Sound 630-350-1500 I pd 100.00 to have it programmed to work in a 2004 F150. I drove there from Milwaukee
Username: Swfrx
I have a 2006 F-150. How can I find out which factory navigation units will work?
thanks
