Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Moss 707 car alarm/immobiliser
Author Thread: Moss 707 car alarm/immobiliser
kida
The alarm is set up ok, arms fine, disams fine. It even goes off when you open the doors, move inside near the sensors and shock the car.
But when I start my engine the leds on the interior sensor keep flashing and the alarm will chirp a few times while the engine is running.
It works fine when the engine isn't started.
Please help! thanks
you seem to have wired the live up to the terminal which is off when ignition turned off..
to correct this find a perminent live with ignition turned off and use this... hope this helps
Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Moss 707 car alarm/immobiliser [ « Previous ] [ Next » ]
