Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > How do i wire into a 2 ohm load
Author Thread: How do i wire into a 2 ohm load
Braden N.
I have two 10" audiobahn subs (Dual Bandpass System) and are rated at 4 ohms. If I want a mono amp, can i wire to 2 ohms? Diagrams would be a big help.
Username: Cadillacdb
Houston , TX
Post Number: 192
Are they 4 ohms SVC or 4 Ohms DVC...if you want to wire them both together an they are 4 ohms DVC then no you cant get them to present the amp with anything other then a 4 ohm load or a 1 ohm load ..... but if they are 4 ohms SVC then yes you can wire them together to present the amp with a 2 ohm load ....
Link to the Woofer wiring Wizard
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=17&image.y=3
Braden N.
i understand that the pos. wire together and the neg. wire together to make a 2 ohm load, but how do they wire together and wire into the amp with one wire?
Username: Fandim
Reno, Nevada
United State...
Post Number: 448
most mono amps still have 4 outputs, 2 pos, 2 neg. Both the pos are actually like hte same input, so you could simply wire them normally, to the amp. pos to pos neg to neg. This would give you your 2 ohm load.
Braden N.
Thanks. But since they have four outputs, does a single svc sub wire into just two outputs?
Username: Fandim
Reno, Nevada
United State...
Post Number: 450
Yes. :-) You can use either output, or both, as they're technically both the same.. (picture like a distribution block)
Braden N.
thanks
I have a 15"inch audiobahn aw152T that is a 4 ohm
load. I need to know if there is any way I can
bring that one woofer to a 2ohm load.My amp is 2ohms at 500w.
Username: Tjmutlow
Post Number: 612
lott, no a single 4 ohm sub is just that it needs to be a dual 4,
Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > How do i wire into a 2 ohm load [ « Previous ] [ Next » ]
