Thread: Im new and need help |
Bronze Member Username: 78elcaminoman
Dallas,
Texas
United States
Post Number: 69 Registered: Jul-05
| Posted on Monday, November 14, 2005 - 01:39 am: |
im sry im new to this car system stuff, what is the purpose of an EQ and a crossover, and do i need one if i got a high wattage system, like i said im new so could yall help me out thanks alot |
| Posted on Friday, December 16, 2005 - 07:33 pm: |
Eq is only for people who want to tweak every little bit of sound out of the system. Its not a neccesity. As for cross overs, they olny send certain notes to speakers. |
Bronze Member Username: Lewass
Bloomfield Hills,
MI
Post Number: 56 Registered: Jan-06
| Posted on Tuesday, February 14, 2006 - 09:24 am: |
If you want to use a stock head unit in your ride, an EQ can be very helpful to have full control over the sound. Not needed for the average system. Crossovers block a certain range of frequency from getting sent to your speakers. For example, if your front speakers are getting any low frequency bass to them, they will start getting distorted. So you adjust the crossover to block those low freq's so your speakers only get delivered sound that is the proper frequency response. |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 11136 Registered: Dec-03
| Posted on Wednesday, February 15, 2006 - 05:59 pm: |
www.bcae1.com explains everything about both.
