Thread: Radar Detector Help |
Silver Member Username: Joebruce
KY
U.S.A.
Post Number: 257 Registered: May-04
| Posted on Wednesday, November 09, 2005 - 07:37 am: |
Alright,i have a 01 s10 and my radar detector does not go off when i turn my truck off,anything that is plugged in the 12v sockets will not go off i have to turn it on/off everytime i get in and out of my truck.Is there any way i can wire it or something so it goes off when i turn off the ignition?Wut about the accessory wires on my wire harness to my cd player can i hook it up to that? |
Zaghloul Saad Zaghloul Unregistered guest |
| Posted on Thursday, November 10, 2005 - 05:09 am: |
About the wire of the CD player, do not do that , because yopu will decrease the Voltage to 85% of the Player, So my advice to you is: 1.Wire a cable(say 'A') 0.7mm thikness from the Battary(+ve). 2. Connect an othre wire (say 'B') 0.7 thikness to any metal part of the boady of the car. 3. connect the both wire 'A' and 'B' to the RADAR Detectors's (+ve) and (-ve) stockets respectively. bye.
Silver Member Username: Sony224422
Deep River,
CT
US
Post Number: 266 Registered: Dec-04
| Posted on Saturday, November 12, 2005 - 11:32 pm: |
i had mine hooked up to my cd player and grounded with my cd player. it worked fine but it was a BBBBB to do. the wires inside are so small. |
