Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > BEST amp to run a Kicker 15" L7????
Author Thread: BEST amp to run a Kicker 15" L7????
Username: Mixmastaspig
Okanagan, B.C
Post Number: 268
and also the cheapest too!!
thanks!
Okanagan, B.C
Post Number: 269
sorry for double post..I cancelled the other one cause of the spelling mistake...I guess it got posted
Username: Rovin
Trinidad & T...
Post Number: 2203
Hifonics BX1000D - ebay
Okanagan, B.C
Post Number: 270
I'll check it out...the amp is for my friend..so I didnt want to reccomened an junker that wont power it
Okanagan, B.C
Post Number: 271
K I checked it out...you can gte the KX1200.1 from Kicker for CHEAPER than that amp
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 1168
Hifonic Bx1500d puts out like 1050 rms, and mike what are u taking about hifonic amps are cheap.
Okanagan, B.C
Post Number: 273
Rovin posted the Hifonics BX1000D - ebay and on ebay its US $439.95 (Approximately C $523.45) and it only gives 350watts mono. K the 2nd Hifonics amp IS cheaper and is it rated at 1500 RMS @ 1 ohm?..so its overrated abit?
well for about 350 you can get the KX1200.1, comparing these 2 is the Hifonics better???
thanks!
Username: Rovin
Trinidad & T...
Post Number: 2206
Mike - i made a mistake thinking that your sub does 750wrms (thats the 12" model ) the 15" does 1000wrms
http://sonicelectronix.com/item_2346.html
U did not say if that sub is either 2 or 4ohms version . If its dual 2ohm version then CB is right with him rec Hif BX 1500D .
http://sonicelectronix.com/item_360.html
A better amp would be JBL 1200.1 if yopur sub is dual 2ohms
OR JBL 1100.1 is your sub is dual 2ohms .....
Okanagan, B.C
Post Number: 278
Dual 2 ohm
Username: Rovin
Trinidad & T...
Post Number: 2208
well this Hifonic Bx1500d as CB said - if his budget is really tight
or for just a few bucks more
JBL BPX1100.1 like i said above.........
Okanagan, B.C
Post Number: 283
is the Kicker the BEST choise out of what youve listed...cause you can buy refurb for around 300 bucks off ebay
Username: Rovin
Trinidad & T...
Post Number: 2219
Yea - Kicker out of those 3 .
Your friend must never crank his vol knob all the way thought cause its possible to blow his sub with that much power or lower the amp's gain level as a precaution ......
Okanagan, B.C
Post Number: 284
Yeah cuase the amp is 1200RMS whereas the sub is 1000rms....I'll explain it to him...I plan to BLOW my Alpine Type R 12's...going to hook them to a DB 1000.2 2000 RMS @ 2 ohms bridged...thata why im looking at the TWS-3002SPL
Username: Rovin
Trinidad & T...
Post Number: 2221
Y da heck would u kill your subs !? - lol
Ebay it instead ....
Okanagan, B.C
Post Number: 286
My subs are 1000 MAX...they will be getting
1000 RMS instead...they are the older version of Alpine Type R's.....I will fry them with that much over power as the AMP is underrated to boot.
Username: Brahmaman
hey i need a 6-700 watt rms amp @ 1 ohm any suggestions and where to get it?
Username: Rovin
Trinidad & T...
Post Number: 2224
mmats 1000.1 on www.woofersetc.com $375 !
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > BEST amp to run a Kicker 15" L7???? [ « Previous ] [ Next » ]
