Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Amp? 2 12" Alpine type E
Author Thread: Amp? 2 12" Alpine type E
Username: J_delbs
My 2 subs are 4 ohm and run at 750 peak 200 RMS. What is the deal? match the RMS or the peak??? and do i need a mono amp? or 2 channel amp? very new at this!! What would be the best amp for my 2 subs??? i prefer alpine amps but....there are probly many other out there that performe just as good or even better for less of a price lol! Back to ? WHATS THE BEST AMP FOR ME???
Username: Rovin
Trinidad & T...
Post Number: 2198
Buy a mono -
Kicker 600.1 amp would bump them nicely - look on ebay ......
Username: Lanzarchamp
Bakersfield, California
United States
Post Number: 206
or if your tight on money check out the jbl 600.1 not a bad choice either there cheap on ebay too
Username: Rovin
Trinidad & T...
Post Number: 2200
Forget i said that Kicker model , would be way too powerful - i got confused with another thread i had open .
Basically u can do a mono amp that does 400wrms @ either 1 or 4ohms like this MTX
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13291
U can also buy a 2 channel amp that does around 200wrms @ 2 ohms in each channel
like this for example
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13877
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Amp? 2 12" Alpine type E [ « Previous ] [ Next » ]
