Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Help! wiring question
Author Thread: Help! wiring question
Username: Buddyleee5
Post Number: 71
i have a kicker kx1200.1 wiring to l7s on a 1 ohm load how do i wire to subs to the amp? and if i have a thunder 564 and a 1200.1 can i hook them up to the same battery or am i gonna need a distrobution block? thanks for any input
Username: Rovin
Trinidad & T...
Post Number: 2169
1 thick rec wire into a dist block then out 2 wires just looks neater . Can also be done with 2 separate wires
wiring guide & additional info on this site
http://www.the12volt.com/info/recwirsz.asp
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Help! wiring question [ « Previous ] [ Next » ]
