Thread: New speakers? |
Silver Member Username: Killer44
Ontario
Post Number: 217 Registered: Dec-04
| Posted on Monday, November 07, 2005 - 12:06 pm: |
i jsut finished the install in my winter vehicle and my sub is drowning out my front stock 6.9's running off my head unit(JVC), they are the only speakers in the vehicle, if i was to replace the 6.9's with new speakers would it be the same or noticably louder, also the head unit has wires for 2 rear speakers, if i wanted to add rear speakers would i just directly connect the speaker wire to these wires?....thanks in advance |
Silver Member Username: Tjmutlow
Post Number: 110 Registered: Sep-05
| Posted on Monday, November 07, 2005 - 03:21 pm: |
Put a four channel amp on them and add rear speakers |
Ontario
Post Number: 218 Registered: Dec-04
| Posted on Monday, November 07, 2005 - 06:24 pm: |
sorry if i didnt make it clear, but this is just my system for my winter car, so i dont really feel like spending money on an amp, i already got a system in my summer car...so ne one else? |
Ontario
Post Number: 219 Registered: Dec-04
| Posted on Tuesday, November 08, 2005 - 11:20 am: |
ne one else? |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 590 Registered: Oct-04
| Posted on Tuesday, November 08, 2005 - 12:43 pm: |
The only way you're going to match volumes is by an amp, I think. |
Ontario
Post Number: 220 Registered: Dec-04
| Posted on Wednesday, November 09, 2005 - 11:34 am: |
so how would i go by adding another amp if my h/u only has one set of outputs...is their a way to add another amp? |
| Posted on Thursday, November 10, 2005 - 06:41 am: |
your stock speakers are 8 ohm that means if your radio puts out 10 watts the front speakers are only getting 5 watts if they are stock speakers i would suggest getting a cheap pair of jensen three ways and hooking up both the front and rear channels to the jensens doubling your power making it as loud as possible (if you do that to the stock speakers they might blow) if that isnt enough sell those jensens for 30 and put down another 30 for some infinitys and get an amp all you need to hook up another amp is a rca Y adapter that plugs into the rca spot and gives you two rca sets one for the subs and one for the other amp you can get that at walmart radio shack really some jensen three ways and a jensen amp would be cheap and sound twice as better then now for only 60 bux jensen speakers have a warm vocal tone as long as they dont have a lot of bass going to them or look for some used infinitys and a jensen amp jensen amps do their job unless your head unit can turn up loud enough to make them distort your jvc will distort before the jensen amp would a little history lesson.. jensen was top of the line about 30 years ago infinity ruined them while fisher was an over priced rival with lesser quality and more volume plus you can put that jensen amp under the driver seat and itll be a butt warmer after an hour or so at high volume (youll burn your hand on that amp before it shuts off :P) |
Ontario
Post Number: 232 Registered: Dec-04
| Posted on Friday, November 11, 2005 - 05:27 pm: |
so would i have to buy 2 rca y adaptors? one for each side of the output(left and right).... |
| Posted on Friday, November 11, 2005 - 09:48 pm: |
yes |
