Thread: Lights dimming in '98 Monte Carlo |
New member Username: Hammer0159
Post Number: 2 Registered: Nov-05
| Posted on Sunday, November 06, 2005 - 08:29 pm: |
I have two 10" infinity subs with 350 rms being powered by a kenwood mono amp putting out 500 rms in a 1998 monte carlo ls. The headlights tend to dim, not horribly, but to a noticeable extent. What would be the first step to fixing this. Also, i was told that having a "system" will reduce gas mileage, can anyone shed some light on this? Thank you |
Silver Member Username: Bestmankind
Los Angeles,
CA
Post Number: 230 Registered: Oct-05
| Posted on Sunday, November 06, 2005 - 09:07 pm: |
get a HO alternator. |
New member Username: Rwsilver1
Post Number: 1 Registered: Nov-05
| Posted on Sunday, November 06, 2005 - 09:16 pm: |
check all grounds to make sure they are not loose |
