Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > What gauge power cable?
Author Thread: What gauge power cable?
Username: Yinyang
CA
Post Number: 19
It's about 8-9 feet from battery to rear inside my '03 Celica. I'm running Infinity Perfects 6.1 and 5.1's comp's and a single 10w7-3 in an H.O. box. My amps are JL 300/4 and JL 500/1. total RMS is about 800 watts. What gauge power cable should I use for optimum performance? Oh yeah, I also have a 1 Farad Digi Cap.
Right on in advance.
Username: Rovin
Trinidad & T...
Post Number: 2152
use this
http://www.the12volt.com/info/recwirsz.asp
Username: Big_oso
Post Number: 531
Just use 1/0 from bat to a ditro block then dual 4 to each amp that way if you decide to upgrade the wiring is already there.
Username: Tjmutlow
Post Number: 98
just use the 4guage, it is sufficient for those amps, I run the 450/4 and the 500/1.
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > What gauge power cable? [ « Previous ] [ Next » ]
