Thread: Jbl 1200.1 or jl 1000/1 |
schoolhouse Unregistered guest |
| Posted on Tuesday, April 20, 2004 - 12:07 pm: |
just wondering which one you guys would choose.. jbl 1200.1 jl 1000/1 |
| Posted on Tuesday, April 20, 2004 - 02:11 pm: |
if price is not a factor.... JL 1000/1 |
Silver Member Username: Its_bacon12
Post Number: 459 Registered: Dec-03
| Posted on Tuesday, April 20, 2004 - 02:43 pm: |
pending on what im running, i might want the extra 200w rms |
NorthWest,
Michigan
Post Number: 2091 Registered: Dec-03
| Posted on Tuesday, April 20, 2004 - 06:00 pm: |
the actual output of the 1000/1 is closer to 1400wRMS. the thing to consider is if you need the 1 ohm stability of the JBL or of JL'2 1.5 ohm rating is enough, and keep in mine at 4 ohms, the JBL is 600wRMS. The JL at 4 ohms is still a full "1000 watts" however with two subs, that's ~500+wRMS per sub.. the JL will divide power between subs in parallel. The JBL will double its output when going from 4 to 2 ohms. It's a matter of matching the amp's output to the subs you'll be using.
New member Username: Igotbass2
Da burgh,
Pa
Ur kiddin
Post Number: 10 Registered: Apr-04
| Posted on Wednesday, April 21, 2004 - 03:01 am: |
lolol ur kiddin right comparing a jl amp to a jbl wow~~~!!!! |
NorthWest,
Michigan
Post Number: 2105 Registered: Dec-03
| Posted on Wednesday, April 21, 2004 - 09:20 am: |
er, "JL's 1.5 ohm minimum rating" and "keep in mind" typos wish I had a way to edit messages already posted it'd make life easier
