Thread: A JBL amp? |
jojo12345 Unregistered guest |
| Posted on Sunday, November 06, 2005 - 11:00 am: |
im thinking of getting a amp to go with a couple of my pioneer subs. http://www.caraudiocentre.co.uk/product.asp?product=21235 im thinking of getting a JBL amp. http://cgi.ebay.co.uk/JBL-AMPLIFIER-GTO-75-4-AMP-FOR-SUBS-AND-6x9-Speakers_W0QQi temZ5826040763QQcategoryZ18796QQcmdZViewItem will this amp be compatible, if not what other amp would you reccomend. Thanks btw im from the UK |
| Posted on Sunday, November 06, 2005 - 11:02 am: |
or any from there, lol thanks http://stores.ebay.co.uk/AutoPowerOnline-co-uk_AMPLIFIERS_W0QQcolZ4QQdirZ1QQftid Z2QQtZkm |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 2124 Registered: Jul-05
| Posted on Sunday, November 06, 2005 - 12:32 pm: |
I own a pair of those subs ! that's exactly how much they sell for in my country . Do u have the 4ohms SVC or DVC version ??????? They are actually rated @ 400wrms EACH so there's no way would bump them to full potential with that amp . MONO amps are what are rec for subs - u can also use a 2 chan amp . None of those JBL on that page is perfect since most don't have your required power & that 1200wrms model maybe a bit too powerful . u can still get it but turn your gains & volume knob conservatably .......... |
| Posted on Sunday, November 06, 2005 - 12:52 pm: |
ummm i dont really now about the spec becuase i got it off that site, thats all the details i have. What amp would you reccomend, thanks ;) |
| Posted on Sunday, November 06, 2005 - 01:00 pm: |
what power of amp should i be looking at? |
Trinidad & T...
Post Number: 2126 Registered: Jul-05
| Posted on Sunday, November 06, 2005 - 01:02 pm: |
"Do u have the 4ohms SVC or DVC version ??????? " i need to know the VC config of your subs or i can't rec anything . If u do own those subs already - how many terminals are on each sub ? 2 or 4 terminals ? |
| Posted on Sunday, November 06, 2005 - 01:24 pm: |
there svc, and 2 termianals (i think) |
Trinidad & T...
Post Number: 2131 Registered: Jul-05
| Posted on Sunday, November 06, 2005 - 01:38 pm: |
if 2 terminals for sure - then they are obviously 4ohms SVC cause Pioneer makes em only in 4ohms So what u need is a MONO amp that does around 800wrms @ 2ohms The Hifonics BX1605 should do fine - if u r on a tight budget ..... Can u get the common USA brands in Eng ? - what available brands u have in your area ? |
joseph12345 Unregistered guest |
| Posted on Sunday, November 06, 2005 - 03:33 pm: |
i wont talk about the wack ones. We can get ,Alpine, Kenwood, JBL, Pioneer, In Phase etc, we can get a couple different ones on ebay. There are some tht aint even got a proper comapany name ie http://search.stores.ebay.co.uk/search/search.dll?query=1500w%2BCar%2BAmplifier% 2C%2B2%2BChannel%2BAmp&fcl=3&fci=-1&fsn=The%2BLoudest%2BCom&fcd=2&sofp=0&from=R1 0&sasel=70079008&fsop=1&fsoo=1&submit=Search. Sorry if that aint much info but im just startin out in car audio |
Trinidad & T...
Post Number: 2148 Registered: Jul-05
| Posted on Sunday, November 06, 2005 - 04:41 pm: |
Oh - well if u do get Alpine then the MRD M10005 is a perfect match up for those subs & it reasonably priced too ....... |
Trinidad & T...
Post Number: 2149 Registered: Jul-05
| Posted on Sunday, November 06, 2005 - 04:42 pm: |
M1005 - that is |
| Posted on Sunday, November 06, 2005 - 08:31 pm: |
cheers |
