Thread: DVD Codes & DVD Unlocks - Multi-Media Systems |
ICE-XXX Unregistered guest |
| Posted on Saturday, November 05, 2005 - 06:10 am: |
If you're interested, check out the following site for a decent database of DVD unlocks. It's got a few machines that other sites don't feature, so I'm recommending it. It seems a good place to go for those rarer machines by the looks of things. It's actually got a Sony unlock code on one of its front pages. I don't know whether it works though, as I heard Sony machines can't be unlocked with a handset? Anyway, here's a link to the free page - the DVD codes might be of some use to you. www.dvdexploder.com/multihacks |
| Posted on Monday, December 19, 2005 - 05:25 am: |
I have a sanyo progressive scan dvd player & vcr dvw-7200. it 2 months old and and now it wont show a pic on it from dvd it use to i it needed a unlock code to fix it can any one help. PLEASE |
New member Username: Mareolulo
Post Number: 1 Registered: Jan-06
| Posted on Wednesday, January 04, 2006 - 05:12 pm: |
I have a durabrand dvd portable player of 6.2 inches. The model is PVS1262. I need to know how to unlock region of this dvd portable player.. Thank you |
Post Number: 3 Registered: Jan-06
| Posted on Wednesday, January 04, 2006 - 05:13 pm: |
I have a venturer dvd portable player of 6.2 inches. The model is PVS1262. I need to know how to unlock region of this dvd portable player.. Thank you |
New member Username: Michaussie
Post Number: 1 Registered: May-06
| Posted on Thursday, May 18, 2006 - 01:39 am: |
Hi, i purchased a kenwood ddx-7035 incar stereo from ebay about a year ago that was supposed to be region free. Is there an code that will unlock this and make it region free? |
New member Username: Spiron
Post Number: 2 Registered: May-05
| Posted on Monday, May 29, 2006 - 02:02 pm: |
Mich, I have exactly the same problem. Bought it also a year ago, and I did start a complaint and refund procedure on e-bay but ofc the user that sold it just disappeared. I've bought and tried several methods but nothing worked so far. The method supposedly to work for the DDX-7015 was : * insert DVD, wait for the 'region code error' to appear * turn off using src * turn on using src and hold play for 10 seconds It didn't work for me, so doubt it will work for you, but it's the only method I've found online so far... If anyone has any ideas, I'm pretty desparate. Regards J |
