Thread: Audiobahn A8000T Amp. w/ 12 Kicker L7? |
New member Username: Kickersubs21
Michigan
United States
Post Number: 1 Registered: Nov-05
| Posted on Friday, November 04, 2005 - 09:00 pm: |
I plan on Buying a 12 inch kicker L7 (750w rms, 1500 w peak) with an Audiobahn A8000T amplifier. I was wondering if i plan on using it at 2 ohms (800w x 1 RMS) should i get the dual 4 ohm voice coil model or dual 2 ohm model? I read on one website that the dual 4 ohm was for putting 2 or 8 ohms into it and the dual 2 ohm was for putting 1 or 4 ohms into it. Any help would be appreciated, thanks. |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 397 Registered: Jun-05
| Posted on Friday, November 04, 2005 - 09:10 pm: |
Hope you realize you'll need two of those amps. Audiobahns arent known for putting out 100% of their claimed RMS power, to begin with.. You should go with the dual 4 ohm model, and wire them parallel, and run one of those amps to each one at 2 ohms each.
Silver Member Username: Robert_d
MIA,
FL
Post Number: 314 Registered: Sep-05
| Posted on Friday, November 04, 2005 - 09:27 pm: |
try a hifonics 1000.1 and get dual 2 ohm that should put around 800 rms |
Silver Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 954 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 11:53 pm: |
if your on a budget try a Hifonic 1605D or even a 2000D, since they only put out about 70% |
Huntsville,
Alabama
U.S.
Post Number: 955 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 11:55 pm: |
bump |
Bronze Member Username: Cadillacdb
Houston ,
TX
Post Number: 20 Registered: Aug-05
| Posted on Saturday, November 05, 2005 - 01:59 am: |
The amp will put out about 750rms at 2 ohms an after losses which are always present you will be puttin about 700 rms into the sub which is enough an get Dual 4 ohm so you can wire ittopresent the amp with a 2 ohm load ..Audiobahn amps are a tad bit over rated when it comes to there RMS claims but dont worry the amp will be enough power for that particular sub |
Huntsville,
Alabama
U.S.
Post Number: 991 Registered: Jul-05
| Posted on Saturday, November 05, 2005 - 02:13 am: |
dude, my bad i dont no why i thought u where getting 2 l7's |
Huntsville,
Alabama
U.S.
Post Number: 992 Registered: Jul-05
| Posted on Saturday, November 05, 2005 - 02:14 am: |
the bahn will be fine |
| Posted on Saturday, November 05, 2005 - 11:09 am: |
I heard that audiobahn amp actually puts out like 780 watts RMS. Even if it did put out 750 watts RMS, that is still a good deal, 750 watts for only $140. |
Houston ,
TX
Post Number: 31 Registered: Aug-05
| Posted on Saturday, November 05, 2005 - 08:53 pm: |
Yeah..Between 780 to 750 RMS is well worth 140..the thing is that you cant ask 140 for it used when people can buy it on ebay for 140 new so i would sell locally or trade it for some sh*t at an Audio Store that does trading ..ive taken in a junky old jensen an got 100 on the trade at Audiotek in South Houston |
Houston ,
TX
Post Number: 32 Registered: Aug-05
| Posted on Saturday, November 05, 2005 - 08:56 pm: |
Hold up i posted that last comment in the Wrong thread,,,my bad |
Michigan
United States
Post Number: 2 Registered: Nov-05
| Posted on Sunday, November 06, 2005 - 07:44 pm: |
Thanks Seth Lowe, so should i get the 2 channel version of the amp instead (The A8002 Model) which puts out 400x2 RMS at 2 ohms? |
Michigan
United States
Post Number: 3 Registered: Nov-05
| Posted on Sunday, November 06, 2005 - 07:45 pm: |
Never mind that last comment, my mistake, i was thinking about something else......... |
