Thread: What amp sould i get got 2 10in L7 |
New member Username: Muddnxj
Post Number: 1 Registered: Nov-05
| Posted on Friday, November 04, 2005 - 07:09 pm: |
ok im getting 2 10 L7 im wording what amp i sould get for them and sould i get 2 amps one for inside 4 and 1 for the substhanks for your guys help |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 2070 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 07:41 pm: |
yes - get 2 separate amps . Mono like Kicker 1200.1 for subs how many coax or components speakers u got 2 or 4 ?????? |
Post Number: 2 Registered: Nov-05
| Posted on Friday, November 04, 2005 - 07:54 pm: |
i dont have anything yet im getting it for x mas i have a jeep xj i am going to have 2 front to rear |
Trinidad & T...
Post Number: 2073 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 08:14 pm: |
u mean 2 speakers in fr & 2 in rear + 2 subs ????? what size of speakers can fit ? |
Post Number: 3 Registered: Nov-05
| Posted on Friday, November 04, 2005 - 08:20 pm: |
they are 5.5 by 4 or something like that |
Trinidad & T...
Post Number: 2074 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 08:37 pm: |
Take a ruler & go measure it ! - lol Better if u used Components instead or regular coax . Brands to check out - Infinity , JL , CDT , Alpine , Image Dynamics , MB Quart , Diamond Audio etc ..... |
Post Number: 4 Registered: Nov-05
| Posted on Friday, November 04, 2005 - 08:45 pm: |
ok im dont know much about this stuff but is L7 good subs is clarion a good for cd player and what L7 sould i get the s10L72 or the s10L74 thankz |
Trinidad & T...
Post Number: 2075 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 09:28 pm: |
here's a quick guide http://pub14.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=27.topic alot of ppl here do not like any sqare Kicker subs but the Kicker compvr series is good . The current rage in subs right now is Alpine Type R & type X subs for really loud . 2 12" Rs & a Kicker 1200.1 amp is a good set-up . Also Diamond Audio D6 12s are very decent to . If u have alot $ then subs by JL are superb . If u pick 2 subs = the 1000 to 1500wrms range then get 4ohms dvc subs cause the MONO amp will be ALOT cheaper . Picking high rms subs like say a 1000w each will call for big amps which will require ALOT of power & car electrical upgrades . 2 subs = to 1000/1200wrms is the norm for good & loud & $ is a major factor too . read this thoroughly http://www.crutchfieldadvisor.com/S-ymhkeYjMfQy/learningcenter/car/
Trinidad & T...
Post Number: 2076 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 09:30 pm: |
Have u already got a good deck ? If Not - then check Premier , Alpine & Eclipse models ..... |
Post Number: 5 Registered: Nov-05
| Posted on Sunday, November 06, 2005 - 05:11 pm: |
no i have not got a deck yet thanz i will look into those ya i have heard alot of good things about L7 my friend got them in his car and they sound good hes got 4 8in one custom box and all that |
