Thread: Phoenix Gold Octane-R 15.0:1 Amp |
New member Username: Spduff2
Louisville,
KY
Post Number: 3 Registered: Oct-05
| Posted on Friday, November 04, 2005 - 11:42 am: |
Just a couple questions about this amp. Why does it have two speaker outputs when it is supposed to be a mono amp?? Is there any specific reason for this. Do I just bridge it as I would a normal two channel?? Also, I can't seem to figure out the gain on this amp. Previous amps I have had have clearly stated which control is the gain, but on this it just has Input Sensitivity, Crossover Frequency, Twin-T Bass EQ (Bass Boost), and Subsonic Frequency. Thanks. |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 2077 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 09:37 pm: |
alot of mono amps have 2 outputs so that u can connect wires off 2 subs easily but it still gets the same mono power - its just to make wiring easier . Input sensitivity IS THE GAIN . |
