Thread: Best amp for 2 12" kicker colobaric s12d |
Bronze Member Username: Eddiebeltoe
Post Number: 66 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 08:28 am: |
hey whatsup i wanted to kno what amp fit best for 2 12" kickers the round model s12d |
Bronze Member Username: Alexv305
Tavernier,
FL
Post Number: 40 Registered: Oct-05
| Posted on Friday, November 04, 2005 - 08:30 am: |
lol solobarics are square not round..you put solobarics in the thread subject.. |
Tavernier,
FL
Post Number: 41 Registered: Oct-05
| Posted on Friday, November 04, 2005 - 08:34 am: |
oops im wrong they are solos.. get a MB Quart RAA1000. puts out 1000w rms.. more than enough |
Post Number: 67 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 01:51 pm: |
dam u think those subs can handle it lmao cuz i dont really kno the specs to them? |
Tavernier,
FL
Post Number: 47 Registered: Oct-05
| Posted on Friday, November 04, 2005 - 02:08 pm: |
dont turn it up too high...plus u will always have room to add more subs |
Post Number: 68 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 02:45 pm: |
by any chance u kno what specs on these subs? |
Silver Member Username: Nutty91rs
Bloomington,
Indiana
Post Number: 109 Registered: Oct-05
| Posted on Sunday, November 06, 2005 - 02:32 pm: |
Physical Specifications * Round 12" cast aluminum, heavy duty frame * 60 oz. magnet weight * 168 oz. magnet structure weight (10 lbs+) * Talc filled Copolymer cone * Santoprene Surround glued and stitched to cone body * 2" , 4 Ohm heavy duty voice coil on space age Kapton former * Sleeved leads to prevent shorting * Perimeter spider vents for additional cooling and smoother performance * Extended pole for exceptional voice coil cooling * Heavy duty lead connectors (will accept 4 gauge wire) * Designed for small sealed enclosure - .88 cu.ft. recommended Technical Specifications * 600 watt maximum power handling capability * 24-100 Hz Frequency Response * Fs =21.79 Hz (Free air resonance frequency of driver) * Qms=8.647 (Mechanical damping) * Qes=0.3870 (Electrical damping) * Qts=0.3704 (Total damping of woofer at Fs) * Vas=131.11 liters (Volume of air having the same acoustic compliance as the enclosure) * Cms=0.3261E-03 M/N (Suspension compliance) * Re=3.47 ohms (DC voice coil resistance) * BL=14.170 Newtons/Amp (Force factor) * Sd=0.053502 sq. mtrs (effective surface area of driver cone) * Mms=0.163589 Kilograms (Moving mass) * Hvc=1.170" (Voice coil winding height) * Hag=.500" (Air gap height) * Xmax=0.335 (Linear excursion, one direction, equals voice coil overhang) * Xlin p-p=.670 (Total linear excursion, peak to peak) * Ref Efficiency=0.3368% * Predicted Output=87.474 Db/1W/1M |
Bloomington,
Indiana
Post Number: 110 Registered: Oct-05
| Posted on Sunday, November 06, 2005 - 02:33 pm: |
The old round Solo Baric D series subwoofers are phenomenal subs, leaps and bounds better than the new square jokes Kicker is putting out. They'll take 1000 RMS in the right enclosure, they're rated at 350RMS and 600max. |
Silver Member Username: Robert_d
MIA,
FL
Post Number: 333 Registered: Sep-05
| Posted on Sunday, November 06, 2005 - 04:14 pm: |
i dont think they make the raa1000 anymore mb quart got taken over by another company it will be hard to find one |
