Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Amplifier and Components
Author Thread: Amplifier and Components
Username: Iufan4lifeul
Post Number: 695
Ok, I have 4 Pioneer 3 ways. I am getting a Kicker KX150.2 (75rmsX2) to power my speakers. Would it be worth it to take out the 4 speakers and replace them with 1 set of components up front? I get an insane discount at CC so buying something from there would be preferable. Out of the following which is the best...
Infinity Reference
MTX 6-1/2" Speaker (TX6001)
Kicker 6 1/2" Speakers (KS6.2)
or (if it would make a MAJOR upgrade over the others) Alpine Type R's. It would be about 30-40$ for the Infinity and Kicker compared to about 70 for MTX and 100 for Alpine.
Username: Robert_d
MIA, FL
Post Number: 298
out of the 4 the R's sounded best to me
the type R's are 4 ohm speakers the kicker is 75 rms at 2 ohms
you would have to get a kx250.2
Post Number: 696
how would the Infinity's sound?
Username: Robert_d
MIA, FL
Post Number: 299
oh yea it would be worth just getting the front comps i dont like the pioneer coaxils
you can probily sell your 4 speakers to some kid for 100$
Username: Robert_d
MIA, FL
Post Number: 300
im not a fan of the refs but the kappas are pretty nice
but alot of people like the refs
just listen to them see what you like
Post Number: 697
MTX's and Kickers components really not worth looking into? And personally, for you, why don't you like the references? Doesn't have good SQ, SPL, or is it too bright etc.?
Username: Alexv305
Tavernier, FL
Post Number: 42
Diamond Audio, Pioneer Premier, MB Quart, Soundstream, and Alpine Type Rs...Look into those brands for components. Might be a little costly but well worth it :-)
Username: Alexv305
Tavernier, FL
Post Number: 43
Oz Audio is another goodie
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Amplifier and Components [ « Previous ] [ Next » ]
