Thread: SONY amp overheats BUT isn't hot |
Ron needs help Unregistered guest |
| Posted on Friday, November 04, 2005 - 12:17 am: |
I have a sony xplod xm-1902gx amp and the thermal indicator light comes on but the amp isn't hot.... sometimes i'll just get in the car and turn on the radio and it goes right into thermal protect mode. Any input would be greatly appreciated |
Silver Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 946 Registered: Jul-05
| Posted on Friday, November 04, 2005 - 01:53 am: |
Have u checked the fuses |
Javier85 Unregistered guest |
| Posted on Friday, November 04, 2005 - 03:41 am: |
I think your amp is dead i've had 2 sonys and a couple of my cousins had sonys and the thermal light came on and that was it there's no way to get it off unless you go get it fixed but you should just get a another amp but trust me don't get another sony. |
Bronze Member Username: Cadillacdb
Houston ,
TX
Post Number: 26 Registered: Aug-05
| Posted on Saturday, November 05, 2005 - 08:28 pm: |
Sony is JUNK just buy somthing different ..maybe get some suggestions from some guys on here before buying your next amp |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 1027 Registered: Jul-05
| Posted on Saturday, November 05, 2005 - 08:48 pm: |
the easiest way to suggest an amp is to no the budget |
Bronze Member Username: Swegs
Post Number: 38 Registered: Jul-05
| Posted on Saturday, November 05, 2005 - 10:05 pm: |
the xplod's explode simple as that |
