Thread: SUB CUTTING OFF AT HIGH VOLUME/GAIN NICE SETUP |
New member Username: Andy305mia
Post Number: 2 Registered: Nov-05
| Posted on Thursday, November 03, 2005 - 10:17 pm: |
i have a rockford fosgate t5002 briged into 2 ohms, and 1 puch p3 12" sub wired into 2 ohms. i have an optima yellow top battery, and a 4 gauge cable and ground. i have it hooked up to my factory radio using a converter for the rca's that hook up into my rear speakers and act as an rca input. when i turn the volume and the gain on my remote bass up the subs cut off but the led light doesnt turn off so i know the amp is on the whole time its happening. can it be my radio? are the cables too small? i have the gain turned up half way on the actual amp. please help |
Silver Member Username: Sony224422
Deep River,
CT
US
Post Number: 255 Registered: Dec-04
| Posted on Thursday, November 03, 2005 - 11:23 pm: |
same thing happens to me. i have the same set up with the rca converter. I have heard that the bass boost remote thats wired to the amp overrides the gain settings on the amp. I'm not sure if this is the case, but i am going to try to disconnect it and see if it stops. you should too, if you have the wired remote hooked in. |
Post Number: 4 Registered: Nov-05
| Posted on Thursday, November 03, 2005 - 11:46 pm: |
that cant be right can it? it supposed to work with the remote, it was made for that. |
Post Number: 5 Registered: Nov-05
| Posted on Thursday, November 03, 2005 - 11:47 pm: |
ill try it though, thanks. any more suggestions out ther??? |
Deep River,
CT
US
Post Number: 257 Registered: Dec-04
| Posted on Friday, November 04, 2005 - 12:04 am: |
right i know, but it says its a bass booster, and people use the gain as a volume control so it sort of makes sense to me. I dunno, i could be wrong. |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 578 Registered: Oct-04
| Posted on Friday, November 04, 2005 - 10:13 am: |
The gain isn't a volume control. You use that to match up the voltage of the HU pre outs to the amp. It's set once and never touched again unless you install a new HU of different pre out voltage. Also, your bass boost can make the amp clip and maybe overheat and it can turn off. www.bcae1.com - Check out for details on clipping and setting the gain correctly. |
