Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > What gauge wire?
Author Thread: What gauge wire?
Username: Scott_t
Post Number: 58
what guage amp wiring kit do i need to wire the orion 1200D amp?
scotty too hottie
probably 2 gauge you can even go with 4 if you dont have the money.
Username: Quickshot
Charlotte, North Carolina
U.S.
Post Number: 359
nah go 0/1 gauge for sure my mtx thunder 942 wont work unless it has 0/1 gauge and your amp is pushing about 300 more watts than mine
Username: Scott_t
Post Number: 59
2 gauge is 1500 watts i think the orion is 2400 peak. and am i going to need a new alt?
Username: Scott_t
Post Number: 60
where can i get 0/1 gauge wire at? can you give me a few places to look.
and can my stock alt on a monte carlo ls handel the amp?
Username: Rovin
Trinidad & T...
Post Number: 2078
use this guide
http://www.the12volt.com/info/recwirsz.asp
any good audio store should sell it .
If your headlights blink - then electrical upgrade is needed . U can also have the voltage tested to be sure when the system is playing full blast .....
Username: James_g
TN
Post Number: 367
Knu Konceptz....for wire.
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 1039
All wire is the same, just get good RCA cables
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1395
so long as they have a good connection, all rca's perform the same.
Username: Tjmutlow
Post Number: 94
First of all look at what the amp requires, if that is the only amp you are running except maybe a 4 channel it can be run on 4guage. Do use good rca's.
Username: Crashfactoryx
Post Number: 19
I have a question on this too, I have 0 gauge from my battery to my distribution block (i used to have a 1600 watt amp that I thought would need it), I now only run little amps (POS's at that, cuz I'm poor :P), is it detrimental to have that big of wire to little amps? I fried the 200watt POS VR3 I had, so far the 250watt Sony Xplod is doing alright..anyone?
Username: Rovin
Trinidad & T...
Post Number: 2160
If u already have that fat wire - leave it as long as it can fit into the amp , it should not be any harm ...
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > What gauge wire? [ « Previous ] [ Next » ]
