Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Wiring in series
Author Thread: Wiring in series
Hazzem
I have two 4ohm dvc subs and i am trying to wire them up to an bridged audison srx2s. When you do this you wire from the positive terminal of the amp to the positve terminal of your first sub. Then you need to run cable from this positive terminal to the positve terminial on the second sub? or can you split the cable before?
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Wiring in series [ « Previous ] [ Next » ]
