Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Amp power on... no sound!
Author Thread: Amp power on... no sound!
Username: Omguhot_letssex
i believe this is an amp problem. what happens: i turn on my deck and the power light on my amp turns green (normal). music plays through the speakers only and no sound comes from my sub. now if i turn off my deck, my sub will make a quick noise making it seem like its getting some sort of signal. could this be a bad connection in the amp or what? the amp is an Power Acoustik Gothic OV2-820 powering a Kole Audio 12(dual voice coil) and both are fairly new and have only been used for about 6 months. I appreciate any feedback
Username: Alias747
MN
Post Number: 822
Check out the RCA cables. I've been in this situation before so trust me, make sure you didn't pinch them or pull on them too hard and stripped out the inside of the cable. Also take a look at the speaker wires for the same thing while you are at it.
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Amp power on... no sound! [ « Previous ] [ Next » ]
