Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Two Kicker L5 15 inchers....
Author Thread: Two Kicker L5 15 inchers....
Username: Alexv305
Tavernier, FL
Post Number: 32
What amp should I use to make these babies slam!! I know they need about 1500 RMS for the pair...So which amp will do the job perfect?
Thanks..
aLeX
Username: Alexv305
Tavernier, FL
Post Number: 33
Oh and its wired at 1 ohm...
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 907
whats ur budget
Username: Mixmastaspig
Okanagan, B.C
Post Number: 255
They are 1000 rms a piece are they not?
if money is no object try the KX 2500.1 or the Dark Blue 1000.2
Username: Alexv305
Tavernier, FL
Post Number: 35
they are 750 rms per sub...so what amp should i get?
IOWA HAWKEYES
if money IS an object, look into JBL or MTX for IMO "average amps", but if even thats too high i guess you could go with a hifonics 2,000 watt amp- because that way the "2,000" watts will really be around 1400 true watts
Home > Message Board > Car Audio > Amplifiers > Archive through November 09, 2005 > Two Kicker L5 15 inchers.... [ « Previous ] [ Next » ]
