Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Delco, Philips, Ford, Grundig, Becker...
Author Thread: Delco, Philips, Ford, Grundig, Becker, Blaupunkt Radio Codes here
Our site can decode a wide range of radios in seconds....
www.radio-code.co.uk
Instand codes, by entering your serial number... its worth a go
All codes are guaranteed manufacturers original codes, and come with 100% support.
i hope someone can help me here we have a vw original vw sat nav/radio system that has had the code changed by someone !! we are a vw dealers and vw can only supply us with the original radio code i am told there are places where they can decode these systems it is a blaupunkt radio navigation system part number 3b0 035 191d can anybody help !!!
radio-code.co.uk
www.dndservices.co.uk offer a post in service and will be able to reprogram this unit for approx 25.00
radio-code.co.uk can not decode vw or audi blaupunkt radios but can decode some philips and grundig ones...
Regards
Steve (www.radio-code.co.uk)
Hello,
I need code please to unlock my RADIO Station.
BMW BAVARIA C RESVERSE II
7 649 475 040
BP9475B2140653
Also, Steps how to enter code inside station.
Many thanks in advance.
Hello,
I need code please to unlock my RADIO Station... Please...
BMW BAVARIA Model # C33
65. 12-8 364 944
AL 6BDU T 0337691
I HAVE A ALPINE SAT NAV WITH A 5 DIGIT CODE USING NUMBERS 1 TO 6, BUT I DONT KNOW IT. A NEW STARTER MOTOR WAS FITTED B4 I BOUGHT IT AND THE SAT NAV WASNT CONNECTED UP TO SAVE THE CODE. CAN U HELP I'VE EXHAUSTED ALL OTHER OPTIONS. THANKS
We can decode 99% of car radios either by our automated system where our website decodes and provides your code online... www.car-radio-codes.com or by sending your radio in for recoding
Username: Unlockcarradios
Car radio codes instantly over the telephone - 07999 680 814 - 0845 838 2378 - we can unlock your FORD, GRUNDIG, PHILIPS, DELCO, BECKER, BLAUPUNKT, CLARION, SONY
Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Delco, Philips, Ford, Grundig, Becker... [ « Previous ] [ Next » ]
