Thread: Need Help djustmenting amp for my 2 12 subs |
New member Username: Adidasboy017
Bartlett,
IL
Usa
Post Number: 1 Registered: Nov-05
| Posted on Tuesday, November 01, 2005 - 04:39 pm: |
I have a Sony 1200 watt amp. And 2 12in pioneer subs, I need to turn in just right to make it sound good. How should I put each on of the 3 levers to it will sound good. And what does BRL stand for on the amp? Thanks Jesse
Gold Member Username: Suleman36
Maryland
U.S.A.
Post Number: 2457 Registered: Feb-05
| Posted on Tuesday, November 01, 2005 - 05:22 pm: |
What Voltage is your Head Unit ? Like what voltage is your preouts. |
Bartlett,
IL
Usa
Post Number: 2 Registered: Nov-05
| Posted on Tuesday, November 01, 2005 - 06:55 pm: |
i think 50w does that sound right? |
Silver Member Username: Quickshot
Charlotte,
North Carolina
U.S.
Post Number: 351 Registered: Aug-05
| Posted on Tuesday, November 01, 2005 - 06:58 pm: |
nah thats your max wattage rating the head unit actually puts out around 20rms..what kind of head unit do you have?
Bartlett,
IL
Usa
Post Number: 3 Registered: Nov-05
| Posted on Tuesday, November 01, 2005 - 07:03 pm: |
pioneer want the model number like the type it is |
Maryland
U.S.A.
Post Number: 2461 Registered: Feb-05
| Posted on Tuesday, November 01, 2005 - 07:30 pm: |
Yeah that could help and if you know what the voltage of your preouts are. It should say on the box or in the manual. That is important and then i could help you adjust your gains close to what they should be at. I whould turn down the bass boost knob. Set your lpf to about 80hz for starters on either your HU or AMP and not both. You can turn it off on your amp if you have that option by going to full or off. I dont know to much about the sony amps but most amps offer simliar controls. Do you have your subs sealed or ported ? |
Bartlett,
IL
Usa
Post Number: 4 Registered: Nov-05
| Posted on Tuesday, November 01, 2005 - 10:39 pm: |
would it help if i took pictures of the amp control so you can see what they look like and tell me how to set them? |
Maryland
U.S.A.
Post Number: 2464 Registered: Feb-05
| Posted on Wednesday, November 02, 2005 - 01:58 am: |
Yeah that whould help. Find out what your HU preout voltage is first and then i can go over the rest for you |
Bartlett,
IL
Usa
Post Number: 5 Registered: Nov-05
| Posted on Wednesday, November 02, 2005 - 06:53 pm: |
here http://buy.overstock.com/images/products/L1018916.jpg |
Maryland
U.S.A.
Post Number: 2476 Registered: Feb-05
| Posted on Wednesday, November 02, 2005 - 07:01 pm: |
I know the amp controls but what is your Pioneers Preout Voltage. It should be either 2 volts or 4 volts or 6.5 volts etc... |
Bartlett,
IL
Usa
Post Number: 6 Registered: Nov-05
| Posted on Thursday, November 03, 2005 - 11:52 pm: |
2076_15221_49927896%2C00.html,http://www.pioneerelectronics.com/pna/product/manu al/display/0,,2076_15221_49927896,00.html Does this help? |
