Thread: I wanna make my subs hit harder |
Bronze Member Username: Bigherm78
Monmouth,
Or
Usa
Post Number: 13 Registered: Oct-05
| Posted on Friday, October 28, 2005 - 10:03 pm: |
i have 2 12 inch pionieer 600 watt subs and a 1000 watt phoenix digital amp that is 1000 watts and i cant get them to hit hard the subs sound like they are laging or cuting out |
nick_sq Unregistered guest |
| Posted on Friday, October 28, 2005 - 10:41 pm: |
ported box? Cap? dynomat? |
Monmouth,
Or
Usa
Post Number: 14 Registered: Oct-05
| Posted on Friday, October 28, 2005 - 11:33 pm: |
i got a sealed box |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 1805 Registered: Jul-05
| Posted on Friday, October 28, 2005 - 11:45 pm: |
thats your answer right there . Sealed with those subs hold back the true potential of what they can do - port it to specs & your eyes/mouth will open ... |
Monmouth,
Or
Usa
Post Number: 15 Registered: Oct-05
| Posted on Saturday, October 29, 2005 - 12:09 am: |
they hit hard before but not as much since i rewired my deck from a direct power source to the normal one for the radio. they sound like there laging or sound like they cant handle the bass but i know they can |
Trinidad & T...
Post Number: 1809 Registered: Jul-05
| Posted on Saturday, October 29, 2005 - 12:15 am: |
now u are describing what really happened - then put it back & see what happens |
Monmouth,
Or
Usa
Post Number: 16 Registered: Oct-05
| Posted on Saturday, October 29, 2005 - 12:16 am: |
it killed my battery that way |
Trinidad & T...
Post Number: 1810 Registered: Jul-05
| Posted on Saturday, October 29, 2005 - 12:30 am: |
the only way i can think that would happen is if u wired your amp rem wire directly too or 4got your deck on overnight ...... |
Monmouth,
Or
Usa
Post Number: 17 Registered: Oct-05
| Posted on Saturday, October 29, 2005 - 02:01 am: |
wut is the amp rem wire |
Silver Member Username: Iufan4lifeul
Post Number: 623 Registered: May-05
| Posted on Saturday, October 29, 2005 - 10:24 am: |
That is what happened right there matt! The amp remote wire lets the amplifier know when the HU is turned off so it can turn off. If you didn't have this, the thing would just keep running! |
Trinidad & T...
Post Number: 1815 Registered: Jul-05
| Posted on Saturday, October 29, 2005 - 10:38 am: |
thats what i was getting @ -lol . If your rem wire is connected to the + batt terminal then the amp does not turn off even if deck is turned off . The light on the amp will indicate that . The rem wire is supposed to go on the deck's rem wire (usually its BLUE) so when the deck is switched off the amp automatically is shut off ... Hope that was the problem & both of us was helpful . |
Monmouth,
Or
Usa
Post Number: 18 Registered: Oct-05
| Posted on Saturday, October 29, 2005 - 04:17 pm: |
thanks alot man i think it might have gottin undone |
Monmouth,
Or
Usa
Post Number: 19 Registered: Oct-05
| Posted on Sunday, October 30, 2005 - 05:43 pm: |
well i did that and they still are sound like they are lagging is there anything else that will make them hit harder |
| Posted on Sunday, October 30, 2005 - 07:12 pm: |
Yeah turn your gain and bass boost all the way up!!! |
Monmouth,
Or
Usa
Post Number: 20 Registered: Oct-05
| Posted on Sunday, October 30, 2005 - 07:28 pm: |
i think u said the same thing before and everyone was like dont do that so i wont trust you but the bass boost is all the way up and they still lag |
WILLEATYOURSYSTEM Unregistered guest |
| Posted on Friday, November 04, 2005 - 09:22 am: |
well for all of you retards, maybe he just has his subs wired wrong? pos to neg or neg to pos? if u do that backwards even on one side it wont beat hard at all...but u guys gotta get all technical... |
Silver Member Username: Killerzracing71
Fredericksbutg,
Virginia
United states
Post Number: 122 Registered: Aug-05
| Posted on Friday, November 04, 2005 - 09:46 am: |
makes since alot of since |
