Thread: High current amp |
| Posted on Friday, October 28, 2005 - 02:13 pm: |
well thanks to you guys im selling my audiobahn subs and buying some better ones. lol I had one question though, i know everybody hates audiobahn but i bought the 1500hct amp for 200 bucks. i see it on the internet retailing anywhere from 500-900 dollars, the only thing i have heard bad about them is that they need a lot of power. Could i still have a pretty respectable setup with this amp and maybe two eclipse subs? It says it puts out 2000 rms, do you guys think its overated? thanks for the input |
Silver Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 758 Registered: Jul-05
| Posted on Friday, October 28, 2005 - 02:17 pm: |
good amp, im not sure about 2000 but def 1800+ |
| Posted on Friday, October 28, 2005 - 05:55 pm: |
also i know its 1 ohm stable but can i run it safely at 1/2 ohm for 4000 watts rms? |
Huntsville,
Alabama
U.S.
Post Number: 772 Registered: Jul-05
| Posted on Friday, October 28, 2005 - 08:32 pm: |
you might burn off the vc on your sub |
Gold Member Username: Carguy
Post Number: 4920 Registered: Nov-04
| Posted on Friday, October 28, 2005 - 08:41 pm: |
Do not run the amp at 1/2ohms. You will blow it. Unlike human body that gets stronger, electronic components die instantly when pushed past it's limit and will not recover. |
Bronze Member Username: Cadillacdb
Houston ,
TX
Post Number: 27 Registered: Aug-05
| Posted on Saturday, November 05, 2005 - 08:40 pm: |
The A1500HCT is a great amp ...Audiobahn subs are questionable but i would say that the A1500HCT amp will put out atleast 1900rms at 1 ohm an after losses (which are always present ) i would say youre in the 1850rms Ball park in the end |
Houston ,
TX
Post Number: 29 Registered: Aug-05
| Posted on Saturday, November 05, 2005 - 08:43 pm: |
Hold up it might even put out 1950rms because ive had the a2300hct amp tested an it put out 2300rms at 1 ohm mono which is 100rms lower then what it claims to be capable of but since the A1500HCT is a class D amp it might even be less off then what it claims |
Houston ,
TX
Post Number: 30 Registered: Aug-05
| Posted on Saturday, November 05, 2005 - 08:45 pm: |
BTW, what Audiobahn Subs did you have ? |
