Thread: Refurbished? |
Bronze Member Username: Mattman111
Keizer,
OR
US
Post Number: 47 Registered: Feb-05
| Posted on Friday, October 28, 2005 - 01:51 am: |
what is factory refurbished and is it bad to buy it or is it ok? |
Bronze Member Username: Rideredder
Cornell,
IL
Post Number: 86 Registered: Sep-05
| Posted on Friday, October 28, 2005 - 02:34 am: |
Factory refurbished means that the unit had gone bad and had been sent back to the factory to be fixed. You should be alright purchasing refurbished itmes. Plus, the price will be marked down a bit, but it should be good as new. |
Silver Member Username: James_g
TN
Post Number: 362 Registered: Jul-05
| Posted on Friday, October 28, 2005 - 02:45 am: |
Be careful and do your research. Alot of times refurbs are only slightly cheaper than brand new models. If that's the case, there's no reason to buy the refurb. I've seen some refurbs go for $330 when you can get a new model for $360. That makes no sense. |
Keizer,
OR
US
Post Number: 48 Registered: Feb-05
| Posted on Friday, October 28, 2005 - 05:53 pm: |
theres a refurbished orion 250 g4 on ebay for 290 and i was looking at that for my avalanch but im not sure |
Keizer,
OR
US
Post Number: 50 Registered: Feb-05
| Posted on Sunday, November 06, 2005 - 05:11 am: |
To the TOP!! |
Bronze Member Username: Tjmutlow
Post Number: 93 Registered: Sep-05
| Posted on Sunday, November 06, 2005 - 08:37 am: |
Try to get ones that are factory refurbs, orion does not refurb or fix any of their product and have done so in years. |
