Thread: How would you....?!? |
Unregistered guest |
| Posted on Sunday, April 18, 2004 - 11:40 am: |
Just might be a silly question, but how would you go about wiring up 2 subs to a one channel mono amp, or would you even want to?! Any feedback helps. Thanks. im2dyverse@hotmail.com |
NorthWest,
Michigan
Post Number: 2017 Registered: Dec-03
| Posted on Sunday, April 18, 2004 - 02:31 pm: |
sure you could and would.. but it depends on what load the amp is stable to, and the coil configuration of the subs as to how it'd be wired. if the amp is 2 ohm stable and you have two 4 ohm single coil subs, you wire both straight to teh amp in parallel for a 2 ohm load and max output from the amp.
| Posted on Sunday, April 18, 2004 - 05:12 pm: |
if u just take the + and - from 2 dual 4ohm subs and wire them directly to the amp, so theres 2 sets of wire (+ and - from each sub), at what ohm would the subs then be wired? |
NorthWest,
Michigan
Post Number: 2032 Registered: Dec-03
| Posted on Sunday, April 18, 2004 - 08:52 pm: |
mono amp, 1 ohm
Rhino20 Unregistered guest |
| Posted on Monday, April 19, 2004 - 08:13 pm: |
The subs themselves are 2 ohms, (the Apine Type R's, 1000 watt max, 300-350 rms)...
| Posted on Monday, April 19, 2004 - 08:24 pm: |
Also, I might be getting a different amp... a 2 channel 2000 watt Legacy LA2060 amp, which isn't the orginial monoblock amp that I was talking about (the JBL bp1100.1 or JBL 1200.1, as I have access to both), but I'd like to know which of the 3 would SOUND the best (THD, senitivity, Signal-to-Noise Ratio, and all that shitte are important, as well as SPL and SQ)... Also, would the 2 JBL amps overpower my subs?!? Any help would be great... Thanks. |
NorthWest,
Michigan
Post Number: 2069 Registered: Dec-03
| Posted on Tuesday, April 20, 2004 - 12:18 am: |
Legacy is total crap. if you have two type R subs, go with the JBL BP600.1 it's stable to 1 ohm, and will give each sub the 300wRMS that the subs are rated to take. good pairing.
