Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > New alternator?
Author Thread: New alternator?
Username: Nme
My new system will be a 600.1 kicker amp pushing a kicker solo-baric 12. I will also have about 200 watts of 6x9s and 4's. Its going into a 85 monte carlo. Im not sure how strong the current alternator is. But what im wondering is how many amps my system is gonna draw. Thanks
Mark
Shallow means, Deep ends
A high current alt is always a good choice if you can afford it. Unfortunately thats not always the case. I wouldn't worry about it with the setup you described. Just make sure your current alt is healthy and your battery is in good shape.
Pat L
Set up the system, turn the key and see what happens! If the lighting inside and outside the car dims- well than thats a problem...
Username: Glasswolf
NorthWest, Michigan
Post Number: 2004
~75A at full output from the system.
that's the most it'll draw.
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > New alternator? [ « Previous ] [ Next » ]
