Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > New alternator for 2 500 rms amps?
Author Thread: New alternator for 2 500 rms amps?
do you think 2 500 rms class d amps will cause to have a new higher amp alternator? or do you think it will be alright. would it be better to get just one 1000 rms class d amp instead? which would need less amps from the battery 2 500 rms amps or one 1000 watt amp?
Username: Glasswolf
NorthWest, Michigan
Post Number: 1935
1000 watts is the same no matter which way you cut it.
Now as for the alternator, that you'll only know once ya get the system in.
if the lights dim, or voltage drops when teh system is on, yes, you need a bigger alternator, or you need to turn the volume down.
If you don't experience any troubles, you're probably fine.
would i still be ok using 4 gauge for power and ground for the 2 amps? or would i have to get 0 gauge? its stinger hpm 4 gauge i have now, says it can take 1400 watts.
Username: Glasswolf
NorthWest, Michigan
Post Number: 1947
for 1Kwatt, 4AWG should be fine unless you have some reason to need over 20ft of cable from battery to amps.
do you think it would be smart to run a switch for each amp so if it is too much than i could just switch one of the amps off until i get a higher amp alternator?
Username: Glasswolf
NorthWest, Michigan
Post Number: 1962
it's easier to just take the in-line fuse out of the holder.
accomplishes the same thing with less work.
yea but this way i can listen to the radio w/o the other sub on, then when i want it on i can just flip the switch, thnks for the help though
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > New alternator for 2 500 rms amps? [ « Previous ] [ Next » ]
