Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > What amp to use with 300rms sub?
Author Thread: What amp to use with 300rms sub?
What amp should i use to run a 12" 4ohm sub that runs at 300rms?
any help would be nice, new at all this stuff, thanks
if i'm only using one 12" with an amp, should it be a 2ohm or 4ohm?
Username: Its_bacon12
Post Number: 426
you can go with a dual 4 ohm sub and run it with a bp300.1, 300w rms at 2 ohms
or single 4 ohm and get a bp600.1, 300w rms at 4 ohms
either way works but the dual 4 ohm version with bp300.1 will probly save u about $95
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > What amp to use with 300rms sub? [ « Previous ] [ Next » ]
