Thread: Serpi Star GR 44???? |
| Posted on Friday, April 16, 2004 - 06:47 am: |
I need wiring instruction for Serpi Star GR 44... if anyone has it plese send me a copy to mikas@miniotas.lt thanks in advance |
Unregistered guest |
| Posted on Saturday, August 21, 2004 - 11:55 am: |
would anyone have a wiring diagram for a serpistar gd5 car alarm lost mine and want to fit it in another car but stuck thanks in advance |
| Posted on Saturday, October 30, 2004 - 10:16 am: |
can anyone help me out with a wiring diagram for a serpi star kit gr99 t + mk1 + gm39 please. |
Bronze Member Username: Ps1k0
Post Number: 26 Registered: Aug-04
| Posted on Thursday, November 04, 2004 - 12:54 am: |
goto www.bulldogsecurity.com and look up your car. then go into your car and do a kind of "reverse engineer" on the installation of the alarm. in other words, follow each wire to where it meets the factory wire in the car, check the color against that on bulldog and see what it is, write it down then you'll know what wire goes where. bring paper and a number 2 pencil. there will be a test after words. gl
