Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > Anyone have a link for installation?
Author Thread: Anyone have a link for installation?
Username: Kasmos_vxa
I just want to know if anyone knows of any good sites with either a picture of amp installation, or a walk through for a dummy.
Or if anyone is willing to help me out themselves. I posted earlier and only got one response............
Anonymou$
www.sounddomain.com have a few descriptions on installation. Don't know if it will help
Username: Titansrule001
remote wire from the deck to the remote spot on the amp 12v hot wire that is the wire that you run from tthe amp to the + battery terminalmake sure you use a fuse30amp between the amp an battery wire disconnect your batteru first you start ground the amp to the body of the car make sure its got a good connectyion clean one.the shorter the better for the ground wire make sure your input wires are not side by side to the ground wire run the input wires away from the ground so you hear the engin noise in the speakersdepending on the amp 2 0r 4 channels 2channel hook the woofers to the amp 4 channel you can hook more speakers up hope this helps you latter
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > Anyone have a link for installation? [ « Previous ] [ Next » ]
