Thread: Pre-Amp Suggestion. Rodek? |
New member Username: Soundman
Post Number: 3 Registered: Apr-04
| Posted on Friday, April 16, 2004 - 05:11 am: |
Hi Any reviews on Rodek pre amps? Would there be a good choice to hook it up to my system? TQ |
Silver Member Username: Its_bacon12
Post Number: 425 Registered: Dec-03
| Posted on Friday, April 16, 2004 - 10:03 am: |
orion preamps are pretty dern good, i dont know alot about preamps tho, ask glasswolf about these |
NorthWest,
Michigan
Post Number: 1938 Registered: Dec-03
| Posted on Friday, April 16, 2004 - 11:21 am: |
The Orion is terrific, but the one I use is DIN only. It requires you use Orion amps with balanced DIN cables. Same way Zapco's work. I'd need to see the Rodek.
