Thread: Need Amp for 2 Sony Xplod 350RMS |
iamduff Unregistered guest |
| Posted on Friday, April 16, 2004 - 12:39 am: |
I know someone selling brand new Sony Xplods for around $60-$80 for both. They are both 350W RMS and hes just dumb and bought them and now needs cash because of personal things. Is that a good deal? I was looking at amps for these and heard that sony underates thier amps. Would a 1200 watt xplod amp be enough or would 2 760 amps work? Could i hook up 2 760 xplod Amps in my car and if i can how do i do that? Thanks for your help |
| Posted on Friday, April 16, 2004 - 10:44 am: |
or maybe could someone find another amp that would be sub$200 that would have enough power to make these 250RMS Xplods hit hard? I keep hearing the Sony Amps suck but what about these speakers? I tested them against someones Rockford subs and they sounded a little better with the same amp as the Rockfords. Can someone please help me out im a littl new to all this |
NorthWest,
Michigan
Post Number: 1932 Registered: Dec-03
| Posted on Friday, April 16, 2004 - 10:58 am: |
honestly, sony subs are absolutely awful. so are their amplifiers. you want something around 600wRMS x 1 @ 2 Ohms try the: JBL BP600.1 or Kicker KX600.1 Then nwhen you ahve the money, sell the sony subs and look at upgrading to the Kicker CompVR 12" subs. two 2+2 DVC models. They'll be far better, and they are rated for teh same power handling, so it's a simple swap out on the same amp.
| Posted on Friday, April 16, 2004 - 11:03 am: |
hey thanks man. so i can hook up that JBL to both subs? how would i go about hooking 2 subs up to a mono amp? im kinda new but want to learn to do it myself. currently have a box and speaker wire already hooked up |
NorthWest,
Michigan
Post Number: 1936 Registered: Dec-03
| Posted on Friday, April 16, 2004 - 11:17 am: |
the JBL has two sets of speaker terminals just for that purpose. makes it really easy.
| Posted on Friday, April 16, 2004 - 11:21 am: |
ok also another question. these subs are 4ohm. would the JBL be able to pump a high wattage at 4ohms to both these subs ? about how much could it give them both? thanks again n sorry bout the repost was an accident ;) |
NorthWest,
Michigan
Post Number: 1945 Registered: Dec-03
| Posted on Friday, April 16, 2004 - 11:38 am: |
two 4 ohm subs in parallel is a 2 ohm load. that'd be a bit over 300wRMS per sub. just about ideal.
| Posted on Monday, April 19, 2004 - 03:58 pm: |
I dont know much about car stereos and need help. My cousin gave me a 1200 watt sony xplode sub and need to know what kind of amp i need. Ive heard that they suck but hey it was free. |
NorthWest,
Michigan
Post Number: 2056 Registered: Dec-03
| Posted on Monday, April 19, 2004 - 05:43 pm: |
what is the RMS power handling for the sub? I believe 1200w is the max rating. let me know and I can suggest an amp
NorthWest,
Michigan
Post Number: 2057 Registered: Dec-03
| Posted on Monday, April 19, 2004 - 05:44 pm: |
oh, and I need to know the coil configuration for the sub, too just one sub? one voice coil or two? 4 ohms? per coil?
| Posted on Wednesday, April 21, 2004 - 09:41 pm: |
Its 1 XS-L121P5 1200W max input power (350W RMS) 4 Ohm Voice Coil
NorthWest,
Michigan
Post Number: 2159 Registered: Dec-03
| Posted on Wednesday, April 21, 2004 - 09:57 pm: |
| Posted on Thursday, April 22, 2004 - 08:55 am: |
Thanx |
