Home > Message Board > Car Audio > Head Units > Archive through October 19, 2005 > Factory headunit 2005 corolla htcbak
Author Thread: Factory headunit 2005 corolla htcbak
Username: Gavski
Hey there,
I have a 2005 toyota corolla hatchback(Australia)and I am currently in the process of installing an amp to drive a 12"sub.The quality of sound from the factory headunit and speakers is awesome already but i just want more bass.Problem is that theres no pre-outs.So do yous know if its possible to splice into front speakers and send that signal to the amp through high level inputs in which will be a bridged output to the sub.This will mean when I stuff around with trble and fading and all that crap on headunit that front speakers will change with sub?Or will this setup suck balls?Cheers for any feedabck.
Gav
Username: Moondog1212
New York
United States
Post Number: 24
yes you can splice into the speaker wires, if you have high level inputs on your amp. but as for fadeing im not too sure i dont remember, i have had to do that before myself.
Username: Gavski
Also when I looked at colour codes on my rear speakers both RR and RL speakers use Red+ and White- and there is only 1 set of red and white cables going into the head unit.Im guessing they have been spliced together.Is this normal?
Username: Gavski
I've been looking up info on colour codes for wires.Generally for toyotas the remote colour wire is black,but is it connected to the antenna remote or acc/ign wire?
Home > Message Board > Car Audio > Head Units > Archive through October 19, 2005 > Factory headunit 2005 corolla htcbak [ « Previous ] [ Next » ]
