Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > Car amp in my room?? i need help!! pl...
Author Thread: Car amp in my room?? i need help!! please
Username: Shady
hi every1 i have no idea about amps
i have 2 x 150 watt 10' subs (thats all i know about them)
that i want to put in my room with a car amp.
can i do this? do i only need a 12 volt power adaptor?
thanks for all your help in advance
thanks
shady
Username: Glasswolf
NorthWest, Michigan
Post Number: 1918
no.
don't bother.
Username: Shady
thanks glasswolf. can it be done though? will it work?
thanks
shady
ya it does work i did if for a mate but use a deep cycle 12v battery and use a heavy duty battery chager
Username: Glasswolf
NorthWest, Michigan
Post Number: 1943
you need a high current 13.8VDC regulated power supply.
the battery isn't a great idea since the battery can gas under those conditions.
Username: Purplehase_bong
Bc
Post Number: 16
get a battery charger and hook it up to the amp. and run the remote wire to the 12volt supply
Bc
Post Number: 17
Username: Glasswolf
NorthWest, Michigan
Post Number: 1997
a battery charger is a trickle charging device, at low current.
won't work.
OneCrazyMexicanw
The "car battery and charger" trick used in a lot of car audio shops is a really bad way of making a power supply. Finding or building a regulated supply with enough current will cost more than just buying a decent home amp.
OR.......you can get crazy and do this....
1)Take 8 car amps and connect them in series (power input, not sound output)
2)Purchase or make a bridge rectifier large enough to handle about 2000 watts and connect amp array to the + and -(adding a 1 farad cap after rectification is a good idea too)
3)Use a small 12v transformer to power the remote turn ons on all 8 amps
4)Get 2 15" quad-coil subs
5)Make your neighbors cry!!!!!!
I know this sounds completely far fetched but i have done it. You end up with ruffly 15v dc to each amp with as much current as your 120 line and rectifier can handle!!!!
Username: Glasswolf
NorthWest, Michigan
Post Number: 2006
the problem there is that home circuits usually handle at least 3 rooms of a house, or two apartments in a complex, and they are 20A circuits.
Unless you have a dedicated circuit set up for a high current load, and preferably conditioned, you'll encounter problems.
That was the case for a single Krell KSA-250 amplifier with a 4 Ohm stereo load at home.. had to set up a dedicated feed for the amplifier and related components.
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > Car amp in my room?? i need help!! pl... [ « Previous ] [ Next » ]
