Thread: Remote Turn On Wire???? |
Bronze Member Username: Young_james
Post Number: 54 Registered: Sep-05
| Posted on Monday, October 17, 2005 - 09:04 am: |
Hi all, I just got a new Pioneer DEH-P4600MP and there is no remote wire (blue) one to run to my amp. The only wires that are there is the 8 multi coloured ones for the 4 speakers, a red power one, another yellow power one, and the ground. However there is one more wire that says "System Remote Control." It's a blue wire but it got a plug on the end of it so you can plug it into something. I have no idea what this wire is for. I need help on how to get the remote wire to my amp so I can hook one up. Thanks Everyone!! |
Bronze Member Username: Moondog1212
New York
United States
Post Number: 19 Registered: Oct-05
| Posted on Monday, October 17, 2005 - 09:32 am: |
that is probably your "remote" wire, if not just use a wire tap on your acc. wire/ ign. and that will work no prob. |
Bronze Member Username: Nocc1n
US
Post Number: 93 Registered: May-05
| Posted on Monday, October 17, 2005 - 10:06 pm: |
that is your remote wire lol, just cut the end off and it will work. but as brian said will work too |
