Thread: Ipod out vs head units out? |
Bronze Member Username: Yada
Post Number: 28 Registered: Sep-05
| Posted on Monday, October 17, 2005 - 01:47 am: |
I'm wondering. When you use a wire to plug ipod straight into amp vs a nice head unit say DEH-p***. Does it matter that much? What is the different with the different level inputs. High level vs Low level? On the amp's manual it's recommended to use the low level inputs. Doesn't that defeat the purpose of a nice head unit? Say you're using a Kicker KX350.4 bridging to 2 channels running Infinity Kaps. Is it mainly because you can get louder with Hi-inputs? If so what's the reason to use low level instead of high level? |
Gold Member Username: Illuminator
Post Number: 2000 Registered: Apr-05
| Posted on Monday, October 17, 2005 - 03:22 pm: |
The headunit boosts the signal. The voltage coming out from the headphone jack on the iPod is so low, the amp really won't sound very good without the headunit. |
Post Number: 31 Registered: Sep-05
| Posted on Tuesday, October 18, 2005 - 12:51 am: |
Boosting the signal means amping it. Isn't that the job of the amp itself? Using the head unit, it boosts the signal with its own amp (suffice to say that the limitted space of the HU, the amp is semi-crap), then you feed that signal into an external amp. I don't see how this would make the sound sounds better than by just going through 1 amp itself. Most amps nowaday take inputs from Low level anyway and the manual of the KX350.4 recommends using low level inputs from the HU. So are you saying that you should feed the amp HI-inputs for better sound quality? |
Post Number: 2004 Registered: Apr-05
| Posted on Tuesday, October 18, 2005 - 01:53 am: |
Naah, i'm saying use the RCA outputs on the headunit... It's up to you, ultimately. Try both, see which one sounds better and works best for you. |
