Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > 4 ohm & 8 ohm
Author Thread: 4 ohm & 8 ohm
can I wire a 4ohm single voice coile speaker and a 8ohm dual voice speaker to get a 2ohm load? if not what is the best was to wire them
help me please
Username: Glasswolf
NorthWest, Michigan
Post Number: 1914
ok just to get this straight..
both speakers are identical aside from coil configuration..
you have a mono amp?
one sub is 4 ohm SVC
one is 8+8 DVC?
you wire the coils of the DVC sub in parallel to get 4 Ohms.
wire both subs to the mono amp in parallel for a 2 Ohm load.
both subs need to be the same however, so that they move together at teh same time, reproducing the same frequencies in order for the drop in load to occur.
Username: Db18
Post Number: 13
one of the subs is 4ohm svc and the other is dvc 4ohm + 4ohm so how to wire it.
Username: Glasswolf
NorthWest, Michigan
Post Number: 1917
then no you can't get two ohms.
you can come close though.
wire the 4+4 in parallel for a 2 Ohm load, then wire it in parallel with the 4 Ohm sub.
you'll end up with about a 3 ohm load.
power output from the amp will be half way between the 2 and 4 ohm RMS ratings, total.
Username: Db18
Post Number: 14
what is best 4 a two channel amp
Username: Glasswolf
NorthWest, Michigan
Post Number: 1928
you're not going to use a 2 channel amp to drive those two subs.
can't do it
Username: Db18
Post Number: 15
what do you suggest
Username: Glasswolf
NorthWest, Michigan
Post Number: 1944
sell the DVC sub
get another 4 ohm sub just like the first one
use a mono amp rated for about 600wRMS x 1 @ 2 ohms
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > 4 ohm & 8 ohm [ « Previous ] [ Next » ]
