Thread: Amp/Sub for '94 Mustang GT convertible |
New member Username: Mrstangblb
Post Number: 1 Registered: Apr-04
| Posted on Thursday, April 15, 2004 - 09:42 am: |
I just bought a '94 Mustang GT convertible, and it has a CDA-7965 Alpine CD unit in it already, so that's a bit of a plus. There is nothing else with it, though - it is connected to the sorry factory 2 front and 2 rear speakers (NOT Mach 460, but the other sorry speakers). I want to get as inexpensive a subwoofer and amp that I can. My brother has 2 component Clarion 5-1/4"s that I'm going to buy from him to probably put in the front, but I'd like to put two more speakers in the back plus a sub. What are you expert guys' opinions on where to go from here? Please understand I don't want to spend a lot of money - if I can get away with an amp to power one or two subs, that's fine. I don't want to win any awards with it - I just want it to sound good when I'm going to work. It's also a convertible, so I may end up putting the subs in a box in the back seat. Thanks for any help you can give me! Barry Jeremiah 29:11 |
NorthWest,
Michigan
Post Number: 1899 Registered: Dec-03
| Posted on Thursday, April 15, 2004 - 10:57 am: |
if you want the cheapest thing you can find, just go find the cheapest thing you can and buy it. It's going to sound like two cats f**king, but hey, you get what you pay for.
Post Number: 2 Registered: Apr-04
| Posted on Thursday, April 15, 2004 - 12:28 pm: |
I'm not wanting the cheapest thing I can find... I'm legitimately trying to find out what is good economically. |
NorthWest,
Michigan
Post Number: 1915 Registered: Dec-03
| Posted on Thursday, April 15, 2004 - 05:31 pm: |
ok the alpine is a good start for a source look at CDT for component speakers www.thezeb.com excellent stuff, and cheaper than other equal quality stuff like Infinity or JL for subs, look at Kicker CompVR subs www.etronics.com pretty cheap, hit hard, and accurate. amps, try JBL BP series for subs, and P series for a 4 channel for the CDTs. also etronics.com and for power distro www.knukonceptz.com should come out fairly cheap and very nice
NorthWest,
Michigan
Post Number: 1916 Registered: Dec-03
| Posted on Thursday, April 15, 2004 - 05:33 pm: |
Post Number: 3 Registered: Apr-04
| Posted on Friday, April 16, 2004 - 08:35 am: |
Thanks very much, GlassWolf. I sure appreciate your help! |
