Thread: Alternator/Capacitor Confusion |
New member Username: Dougfisher_05
Post Number: 4 Registered: Feb-04
| Posted on Wednesday, April 14, 2004 - 08:48 pm: |
About a month ago i had to pull my system out (two subs in a bandpass, and a sony 444watt amp) because of it damaging my cars alternator (1989 honda civic.) Now just recently i was looking over at crutchfield.com to try and find a system that maybe wouldn't draw too much power (but mine pulled at max less than 200 watts). Well anyway while i was there they told me that if i would've had a capacitor my alternator wouldn't have been damaged, and then i went back another time and they said that my alternator probably was just getting too old anyway, so i shouldn't of had a problem. could anyone help me out here? |
NorthWest,
Michigan
Post Number: 1884 Registered: Dec-03
| Posted on Wednesday, April 14, 2004 - 08:55 pm: |
capacitors are a gimmick and will NOT replaec the need for a larger alternator. just go to ebay.com and get a honda alternator that's around 120-150A. They sell for under $300. That'll solve the problem. you need an alternator capable of supplying the current demanded by the additional draw of your audio system, plain and simple.
Post Number: 5 Registered: Feb-04
| Posted on Wednesday, April 14, 2004 - 09:09 pm: |
where can i find a hihg powered alternator other than ebay or is that the only place? |
NorthWest,
Michigan
Post Number: 1896 Registered: Dec-03
| Posted on Wednesday, April 14, 2004 - 09:35 pm: |
www.mralternator.com www.4alterstart.com www.alternatorparts.com
