Home > Message Board > Car Audio > Speakers > Archive through November 13, 2005 > Focal PolyGlass or Diamond Hex
Author Thread: Focal PolyGlass or Diamond Hex
Username: Need4bass
Post Number: 18
I've narrowed my many options for components to the following.
Diamond Audio s600s Hex
Focal 165V2 Polyglass
Has anyone heard both???
Username: Need4bass
Post Number: 20
I take it not.
Username: Ologyaudio
Columbus, Oh
Post Number: 19
I don't like focal... and Diamond hex is good but there are other options out there :-)
Username: Basshead86
Ocala, FL
Post Number: 2276
i would personally use the Hex's with the silk tweeter.
i don't like harsh tweets, and the inverted metal dome Focal(if that's what it comes with), i was told it has a difficult time getting the imaging right in a car environment.
you should ask your self if you like aggressive, or warm less bright tweeters. then decide on what component set would more suit you.
hope that helps.
Username: Need4bass
Post Number: 21
I have always been partial to a soft dome tweet. I have had many people rave about the focals though. Thats why I was looking for people who actually have or have heard them. Are there better options in the same price range?
Ocala, FL
Post Number: 2297
how much are the focals, and the hex's?
Username: Need4bass
Post Number: 23
I'm willing to pay up to $375 per set. I need 2 sets.
Ocala, FL
Post Number: 2299
hmmmm.. how about some DLS Magnesium Drivers.
great power handling, and they sound Fantastic.
nto sure if they are 375 though.
Username: Need4bass
Post Number: 24
How about a link to a particular DLS model?
Username: Need4bass
Post Number: 25
I found a pair of DLS MS6 Reference Series for $250. How are these?
Ocala, FL
Post Number: 2303
those are the ones i was taling about.
Very Nice set of speakers. they get very loud as well.
my audioshop installed just one set of those in a mazda miata, and you could have sworn there was an 8" sub sealed in the trunk. lol
Ocala, FL
Post Number: 2304
*talking*
Username: Need4bass
Post Number: 26
Would it be worth it to say use the MS6 in the rear and bump to a UP6 or UR6 for the front?
Columbus, Oh
Post Number: 20
Got something for ya to take a look at:
http://www.ologyaudio.com/reviews.html
There are some decent comparisons of a few component sets near the price there.
Username: Need4bass
Post Number: 36
They look a little large... I have read on the Ologyaudios before. I plan on sticking with a production run comp set though.
Username: Jonathan_f
GA
Post Number: 4932
Focals are great if you like that banging trash cans together sound :-).
Username: Need4bass
Post Number: 47
The focal hard domes are truely that harsh????
"Focals are great if you like that banging trash cans together sound" -- like that made by a good pair of MB Quarts ??
Username: Csemaint
Bc
http://www.mbquart.de/en/produkte/car/index.php
check them out
Username: T0asty
Post Number: 35
i like mb quarts
Columbus, Oh
Post Number: 32
haha well I'm not sure what you meant by production run... but if you mean custom drivers... preorders for some are starting in the next 2 weeks or so after we confirm that the prototype meets specs... ;)
Username: Vinnyqh
Portland, OR
Post Number: 16
MB Quarts are bright as well. I would definately go with the diamonds. Those things sound truely amazing, a little less bright then most speakers, but the most natural. You can probably look into Boston Acoustics Pro60s also. Those are nice speakers as well.
If you can make it happen, the diamond hex 3 ways are phenomenal (sp?)! I love the way they image and the sound is superb!
Home > Message Board > Car Audio > Speakers > Archive through November 13, 2005 > Focal PolyGlass or Diamond Hex [ « Previous ] [ Next » ]
