Home > Message Board > Car Audio > Head Units > Archive through October 19, 2005 > How to unintstall factory radio for 0...
Author Thread: How to unintstall factory radio for 02 explorer??
Username: Mattyb789
Post Number: 15
does anyone know how to take out the factory radio??
Theres a large bezel surrounding the radio ( the heater controls are on the bottom and buttons or spots for buttons on the sides.) This bezel comes out. A thin flat blade screwdriver needs to be slipped under this bezel. Once you do that gently pry it outword and put your finger under it and gently work your other hand around the whole bezel. It might feel like your going to break it, but you won't. Befor you do that, pull out the heater contlol knobs to make sure that there are no screws behing them, I cant remember off hand.
**What you will need though are the Install kit and wireing harness. In the install kit, there will be instructions on removal. Hope this helps.
Home > Message Board > Car Audio > Head Units > Archive through October 19, 2005 > How to unintstall factory radio for 0... [ « Previous ] [ Next » ]
