Home > Message Board > Car Audio > Head Units > Archive through October 19, 2005 > Adding an Ipod to my factory Bose sys...
Author Thread: Adding an Ipod to my factory Bose system...??
Username: Mnd643
Hey all, first post ever so bare with me. Ive got a 99 Envoy with the factory bose setup in the truck. I want to connect my ipod to it, but I dont know much about this stuff. Is it possible to hook it up? What would I need?? Thanks,
Matt
Username: Illuminator
Post Number: 1965
http://www.installer.com/ipod/ipodtahoe.html
By clicking on the two highlighted words in the first step, you can see you'll need a cable for your specific wiring harness (around $10) and a controller that controls the iPod. The controller is $180 there. You can find it cheaper here: http://www.cardomain.com/item/PACAUXPOD
If you aren't satisfied with those results, just google it. They're fairly easy to find. Ebay might carry them as well for even cheaper prices.
Home > Message Board > Car Audio > Head Units > Archive through October 19, 2005 > Adding an Ipod to my factory Bose sys... [ « Previous ] [ Next » ]
