Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > ???????????
Author Thread: ???????????
Big Dic Balla
I got a kicker KX 400.1 and 2 12" alipne type R's how should I wire these and how should I have the amp tuned?? thanks
Username: Glasswolf
NorthWest, Michigan
Post Number: 1851
is each sub 4 Ohms, single coil?
Big Dic Balla
The subs are Dual 4 ohm.... and for some reason when I turn them up they will usually cut out... Im pretty sure I have them wired right... their wired for a 2 ohm load... how should I have the X-over bass boost and gain set on the amp?? how about on my eclipse head unit?
Username: Glasswolf
NorthWest, Michigan
Post Number: 1975
if they are two 4+4 DVC subs, that'd be one ohm
that's why they are cutting out
Big Dic Balla
Any suggestions on how i can fix my problem? should I wire them differently? thanks...
Username: Glasswolf
NorthWest, Michigan
Post Number: 1985
ideally, get a 1 ohm stable amp, or two 4 ohm subs.
otherwise, rewire htem in series for a 4 ohm load, and a drastic drop in power.
Big Dic Balla
I tried wiring them in series and I could hardly hear the bass, not enough power... I'm just gonna have to get a 1ohm stable amp, but until then im gonna run them 1ohm off of the KX 400.1 .... will I mess up my amp by running it at 1 ohm? or will it be alright for a week or 2 as long as I don't really turn it up?
Username: Its_bacon12
Post Number: 443
get a bp600.1
sell the kicker amp
Username: Glasswolf
NorthWest, Michigan
Post Number: 2014
you'll put the amp into thermal protection and quite probably damage both the speakers and the amp.
Home > Message Board > Car Audio > Amplifiers > Archive through April 23, 2004 > ??????????? [ « Previous ] [ Next » ]
