Home > Message Board > Car Audio > Head Units > Archive through October 19, 2005 > Front aux input vs rear aux input.
Author Thread: Front aux input vs rear aux input.
ricky g
I hav a creative zen micro MP3 player. How much of a difference is there in a front panel aux input than a rear aux??
ricky g
what do you suggest?
Username: Illuminator
Post Number: 1905
Nothing much really. Though it seems like the cheaper units use front panel inputs-plus front panels are headphone jacks and the rears are usually RCA jacks.
I prefer rear aux inputs myself.
ricky g
so for a headunit with a rear stereo RCA auxiliary input on a 4" pigtail", what do i need to do to hook up my MP3 player to it?(M-Bus to RCA??)
thanks
Post Number: 1925
You can just buy a cable that converts the headphone jack from your mp3 player to RCA.
Like this:
http://www.lg-internet.com/catalog/product_info.php/products_id/632
Home > Message Board > Car Audio > Head Units > Archive through October 19, 2005 > Front aux input vs rear aux input. [ « Previous ] [ Next » ]
